Hello everyone,
I’m having an issue with the Y-axis on my printer, and after further inspection, the problem seems to come specifically from the lower bearing on the Y-axis assembly — possibly even the tensioner pulley itself.
I’ve had this printer for about a year, so I understand that parts can wear out or develop issues over time.
The movement feels okay overall, but during slower travel movements there is a noticeable clicking noise that doesn’t seem normal.
I already checked:
Belt tension
Rail alignment
Frame squareness
Screw tightness and wheel adjustment
Everything else appears fine. The issue seems concentrated in the lower bearing area, or possibly the tensioner pulley bearing.
When moving the bed by hand, the movement feels smooth overall, but the clicking noise seems to come specifically from that section.
Has anyone experienced worn or defective bearings, or a failing tensioner pulley on the Y-axis?
Did replacing that part solve the issue?
I’d also like to know exactly which replacement part I should buy, and if possible, whether anyone has found a good video tutorial showing how to replace it.
Thanks in advance.
