K1 Max filament runout sensor adjustment length
Hello all… Anyone know if there is a way to adjust the runout sensor length so that you can use more of the filamant in the tube? Seems when the sensor does its job there is about 8 inches of filament that can still be fed. My thoughts are you should be able to adjust the length or time before the printer stops the print before failure? Maybe its a software enhancement?
