K1 Max hotbed replacement
I believe the hotbed on my K1 Max has given up the ghost. While I was trying to make a small print I had the temps set to 205 and 55. the nozzle temp then lowered to 131 - 115 and I got the CB[2562] error. After running several checks I was getting no continuity while checking the 2 thick heater wires which go from the mainboard green screw terminal (BED/HOTBED). that suggested to me either the wires are fractured or the hotbed is dead. the wires are integral and cannot be replaced separately so I think a new hotbed is in order.
The only replacement I can find have four wires with spade connectors I need the hotbed with the 2 thick heater wires that go into the mainboard green screw terminal (BED/HOTBED) and the thin 2-wire thermistor lead that goes to ADC-TB.
has anyone else needed to replace the hotbed on the K1 Max and if so where did you source the replacement.
Thanks in advance
