K1 max problem in the nozzle
Buenas,
Tengo un problema a la hora de imprimir con la k1 max, le cambie el pico hace menos de un dia y imprimio bien, hasta que en la tercera impresion que hice se imprimio solo la primera capa y dejo de extruir filamento pero seguia el movimiento.
Alguien sabe cual es el problema por que estoy cambiando de pico nuevamente
It’s probably best to post in English if you want a fast answer…
Google Translate
Hello,
I'm having trouble printing with my K1 Max. I changed the nozzle less than a day ago, and it printed fine until the third print. On that print, only the first layer printed, and then it stopped extruding filament, although the print continued moving.
Does anyone know what the problem is? I'm changing the nozzle again.
How long do you have this printer? I noticed that the extruder can cause some problems with printing, the gears have lesser or no grip on the filament so no material is pushed out of the nozzle!
