Hello everyone!
I have been using the CFS with my K1 MAX since it became available in the Netherlands and have been using it ever since. Until recently, everything was working fine.
Now I keep getting error TC2841, but I’ve checked the knife several times.
The knife looks fine, and the knife moves smoothly.
The movement to the block so the knife triggers also works.
I can also pull the filament out of the heating block without any problems, as the cut actually works fine. Retracting into the CFS seems to be the problem.
I can still print, but at the end, when the filament is supposed to be retracted, I have the problem that the print doesn’t really “finish” until I intervene by releasing the leaver on the heating block.
However, I assume that I would not be able to print in multiple colours at the moment, as I always get the TC2841 error and everything stops.
But the retraction works as soon as I disconnect the heating block and then click on retract.
I am currently at a loss as to where the problem might lie, so I am hoping that someone here might have an idea.
Thanks, Erick
