K1 Max silent board and compatible XY stepper motor
I need some information about K1 max silent (CR4CU220812S12) and 42-60 XY stepper motors. I detected this combination in my K1 max. As I am planning to replace the large pulley, the question arises as I also need to change to 42-48 steppers - to be compatible with the mainboard.
Some information says that the CR4CU220812S12 board does not work with 42-60 stepper motors???
Who knows more about this item?
The printer was delivered withCR4CU220812S12 board and 42-60 xy steppers,
На плате установлены драйверы шаговых двигателей ТМС2209 они будут работать практически с любыми шаговыми моторами, возможно нужно будет только скорректировать параметры run_current и hold_current в printer.cgf под параметры двигателя.
