Hi, I’m having continual problems with supports. I have turned off “roof” and the overhang angle is as default, but they are impossible to remove cleanly.
Any advice??? I wish Creality would sort this as it was never an issue with Cura, otherwise it is simply an awesome printer.
Thanks, in advance.
I turn my support density down to 10-15%. Support top distance of 0.2mm should give a little gap between the model and the support. Finally I uncheck enable support interface. Supports almost fall off. You might have to toggle Advanced to get to a couple of those settings. This is settings for normal not for tree. Basing this on my use of a V3 KE not a K1 but it should be same.
Thanks, I’ll give those a go on my next print and feed back
Just finished an 8 hour print on the K1, 30 hours on my CR10 Max, so can’t complain too much, but the underside is not pretty due to the super stuck supports!!
As usual you are a fount of helpful knowledge. I do a lot of prints that don’t require very much in the way of supports but when I do I have struggled with this KE putting them on so “tight” that I destroy/nearly destroy prints removing them. However, just making the couple of tweaks you suggested in this post, I have had better results by ten-fold. But do you have suggestion for which tree setting(s) you prefer to get similar results as these changes produce when I don’t want lines on a print? As always, thanks in advance!
I try to avoid supports, I’ll redesign a part to avoid them. Anyway here is kind of what I do, still get marks on the face mind:-
Thanks. I have never scrolled down on that menu option to pay any attention to those settings. I will experiment with them now though. Thx!
