I recently purchased the CFS upgrade and then purachsed two CFS feeders.
When installed very often I get an error code saying the Buffer unit failed or a feeder issue.
Error Code FB2864 , I purchased a new Buffet unit did not solve the issue
I recently purchased the CFS upgrade and two CFS feeders. After installation, I frequently encountered an error code indicating a Buffer unit failure or a feeder issue (Error Code FB2864). Despite purchasing a new Buffer unit and a new HotHead cutter unit, the problem persisted. Eventually, I discovered that the issue stemmed from the spring at the bottom of the CFS unit. The spring, which applies pressure to the filament when the CFS motor feeds it, was too tight. After removing one coil from the spring and reinstalling it, the unit has been functioning properly. You can find a video detailing the fix and the amount to cut off hereI found it on YouTube https://www.youtube.com/watch?v=UvSH4l7DwOQ.
