Yesterday I was printing an adaptor using PETG on K1 Max. It was a 19h long print. Around 13 into it, the power went off. The Print head stopped, After few minutes when the power resumed, It asked if I wanted to resume, I said yes, and off it continued printing, I looked at the print later. It looked ok, but then I realised the part from where it resumed printing had weakend and it broke off. So after it resumes the adhesion to the layer below is weak. Has anyone experienced anything similar?
Yes, it’s common for adhesion issues to occur after a power outage and subsequent resumption of a 3D print.
Today I again tried to print, I then deliberately switched off the power to see what happens. After I resumed printing, as the head moved to the home position, I saw that it had left behind a blob on the print. there is no way to get rid of it before the print head returns for printing.
hello same issue here with my recent purchase ive heard about the power loss recovery but struggling with it. exactly same blob on my print …
how did you fix it ?
Hello, I read this topic and noticed that I have a similar problem, I can pause the print using the pause button or using the pause at height function, but when I resume printing, it seems to lose the nozzle location reference, so the layer comes out in a different place than where it should be, does anyone know what could be happening?
I have a k1c.
today started printing, and after some time power has breaked for a moment - the home light had blinked once, less than for a second.
the printer has stopped working and made a reboot. after this it neither offered resume printing, nor provided any manual way to resume printing.
WT…?
I ran into this post searching for a problem I’m having with my k1 max rooted. is it my firmware that is causing this printer to not resume after a power outage? Anyone know the cause? It seems as if others are having the same issue i’m having, but are you guys also rooted in your firmware? or are you guys running stock firmware configs?
