K1 SE Overflow issue
I had an issue with my printer catching on a model resulting in the entire hotend unit to get cover in plastic. I cannot seem to remove the screws that connect the brass part of the hotend I think they’ve been fused into the plastic. The screw that connects the circuit board has also been stripped so I can’t get it removed.
A) is it fine to print with the hotend as is now that a lot of the plastic has been cleaned off or is there any tips for cleaning it without having to remove it
B) any advice on what I should do from here
Provided the wires are not damaged, I don’t see any reason you could not reuse the hot end with a new nozzle.
