K1c 0.6 nozzle filament presets
Hi
I just put in a new 0.6 nozzle. In creality print there is the 0.6 nozzle configuration, but there is no default filament for this nozzle, nor can I import those from the 0.4 nozzle or from another printer. Is this normal? Do I have to create the filaments one by one?
Thanks.
Hello, same issue the difference is that I only have Hyper PLA as an option and when I select Add/remove filaments and check the filaments boxes nothing appears as a preset.
Sorry, Me too… only hyperpla. So I’m using orca slicer, wich does have all presets…¡!!
Hello,
I found a workaround to fix this.
You need to install creality print 5.1 setup the K1c as a 0.4mm nozzle open the advanced filament settings and do the same for the 6.0 creality print.
Then while you have both open edit the Hyper-PLA(on 6.0) preset according to the presets in creality print 5.1 then save as a new preset with a new name.
I came to this conclusion since the Hyper PLA on the 0.4 and 0.6mm nozzle had the same settings. Hope this helps!
