I believe I’m experiencing the same issue others have reported with the K1C 2025 model and CFS upgrade.
Details:
Model: K1C 2025
Firmware: v1.0.0.26.20251024S (service firmware)
CFS not detected
4 red LEDs on CFS
No CFS menu appears
No OTA or USB update option available
Issues I’ve found:
The toolhead/nozzle PCB does not match the install guides. Port layout appears different from earlier K1C boards.
The printer is running service firmware (“S” build) and cannot enter the public firmware channel.
USB and OTA updates both report “up to date.”
SSH access is locked.
I’ve verified wiring, reseated connectors, tested cables, and followed official install instructions.
From what I can tell, this appears to be the same situation others have described where the 2025 hardware revision + service firmware prevents CFS functionality entirely.
Has anyone with a K1C 2025 successfully enabled CFS via firmware migration alone, or does this require a board replacement / retail firmware reflash?
I purchased a K1C printer on 29. 9. 2025 from the Czech e-shop https://www.3djake.cz/. The printer worked reliably and correctly. I purchased the additional CFS-C module on 15. 3. 20:55 from the Czech e-shop www.alza.cz. I followed the instructions step by step, but the printer shows errors and printing is not possible.
For general debugging and troubleshooting, I tried resetting to factory settings, ungind creality cloud, restarting the printer, restarting wifi, firmware update, removing cfs and re-mounting cfs, but none of the procedures fixed the error.
The primary problems are that the printer spends a long time connecting to wifi, or does not connect at all. The second problem is that after connecting to wifi I see it in the creality cloud as online in devices, but when I slice the model and want to select a printer from the list, it doesn’t see mine in the list of available devices. I also tried printing using Creality prinz from a PC. There the model is sent to the printer, but when it starts printing, you can see that the extrude doesn’t work (it doesn’t push out the filament) and the print is paused on layer 1 with the error F00528.
If I send the sliced model to the printer and start printing from the printer display, it works correctly.
During printing, the CFS-C model is displayed in the creality cloud alternately as connected and alternately as “Not inserted”. The camera doesn’t work at all.
Current firmware read from the printer display:
K1C_CFS-C Firmware V1.1.0.27.20251225
CFS-C 1 Firmware V1.0.0.27.20251225
I also tried the previous firmware included on the flash drive:
K1C_CFS-C Firmware V1.1.0.26.20251113
CFS-C 1 Firmware V1.1.0.26.20251113
Checking the current firmware shows “Up to date”.
Can you advise me where the error is? This is not a functional solution, which is why I chose the Creality K1C + CFS. I want to print from the cloud, but this printer does not appear in the available devices to start printing.
Users on the forum indicate that there was a hw change unrelated to the firmware and this is now causing errors, or new PCBs are being sent.
1)
I have a K1C for about two years it’s a solid printer. However, I purchased CFS-C upgraded the firmware and I started getting communications issues with the CFS-C buffer to the K1C. I have never had any type of issues with the K1C. I love it. The I had a very hard time getting the machine to print without the CFS-C the machine doesn’t run right at all. Creality told me to wait until they fix the firmware and software. It has been disappointing and heartbreaking. The cloud print will not remove the CFS from the profile.
hi all, I see the comments are a couple of months old. So I got m K1C 2025 version, printed only few small things till now; so far so good. I wanna move to a multi color system and thinking of getting the CFS-C, although I\ve been reading a lot of different feebacks from people. From those who have experience with it… what’s the actual situation? Is it wirth or should I sell my k1c and get a K2 combo with CFS? Thanks for your feedback.
Turns out chatGPT (don’t use anymore) led me down a rabbit hole of bad information.
For the K1C 2025 you need the CFS -C model and I wasn’t informed of this. Thankfully Creality refunded me the full amount for the CFS.
Since then I have created a successful business on Etsy making medical training and health products as well as flight simulator parts and have had no issues since then.
One piece of advice is that the new ceramic heater block can cause the copper nozzle to fuse with its housing and snap. So before you put in a new nozzle make sure you also use copper anti seize lubricant on the screw part of the nozzle , you only need a tiny drop, this is so next time you want to swap out the nozzle it won’t break like mine did twice during huge printing batches.
Again the printhead motherboard was changed from the prior models and so you must make sure you ONLY buy the 2025 model heat blocks and heater components or it won’t fit. A mistake I made twice. And you can get all this from Amazon real cheap and quick, avoid any of those dodgy online china stores they aren’t better or cheaper and take 10 times longer to ship.
