K1C 2025 + OrcaSlicer: Workarounds for Missing Web Interface
I recently got a K1C 2025 (disappointingly - there was no indication that this would not be an original K1C) and spent considerable time troubleshooting why OrcaSlicer’s Device tab showed a 404 error. Sharing my findings to save others the frustration.
The Problem: The K1C 2025 is a different hardware revision than the original K1C, but Creality doesn’t clearly distinguish them in documentation or marketing. Key differences:
  • Firmware branch v1.0.0.x (not v1.3.x.x)
  • No “Root Account Information” in Settings
  • No web interface served on port 80
  • Different mainboard (incompatible with CFS upgrade kit)
What Still Works:
OrcaSlicer Upload & Print:
  • Printer Settings → Add physical printer
  • Host Type: CrealityPrint
  • Hostname: your printer IP (port 80)
  • Test connection shows success
  • Upload and Print works perfectly
  • Device tab will show 404 — this is expected, no web UI exists
Full Web Interface via Local Fluidd: The Moonraker-compatible API on port 7125 is fully functional. You can run Fluidd locally:
bash
mkdir -p ~/fluidd && cd ~/fluidd
curl -L https://github.com/fluidd-core/fluidd/releases/latest/download/fluidd.zip -o fluidd.zip
unzip fluidd.zip
python3 -m http.server 8765
Open http://localhost:8765, add printer at http://[YOUR_PRINTER_IP]:7125
You get full printer control, temperature graphs, bed mesh visualization, file management.
Camera Stream: The K1C 2025 camera uses WebRTC (not MJPEG) on port 8000. Two options:
  1. Standalone browser tab: Open http://[YOUR_PRINTER_IP]:8000/ directly
  2. Integrated in Fluidd: Settings → Cameras → Add Camera:
    • Name: K1C Camera
    • Stream Type: HTTP page
    • Camera URL Stream: http://[YOUR_PRINTER_IP]:8000/
    • Aspect Ratio: 16:9
Tip: You can enter the local Fluidd URL (e.g., http://localhost:8765) in OrcaSlicer’s Physical Printer → Device UI field for integrated access.
Port Summary (from nmap scan):
Port Service Status
22 SSH Open but password unknown
80 nginx 404 on all paths (no web UI)
7125 Moonraker API (nexusp) Fully functional
8000 WebRTC camera Working
8081 Unknown 404
9999 WebSocket Printer status stream
What Doesn’t Work:
  • Root access (intentionally removed per Creality wiki)
  • Web interface hosted on the printer itself
  • OrcaSlicer Klipper/Octoprint modes (OctoPrint compatibility layer not active)
  • Standard MJPEG camera URLs (/webcam/?action=stream)
Request to Creality: The backend (nexusp/Moonraker on 7125) exists and works. Please consider enabling the web frontend in a future firmware update. The infrastructure is already there. Also provide Root Access.
My Printer Details:
  • Model: K1C 2025 (visually identical to original K1C)
  • Firmware: v1.0.0.22.20250711S
  • Mainboard: CR4SU200382C13
  • Moonraker implementation: nexusp v0.1.1
  • OS: Buildroot 2020.02.1, kernel 5.10.186
Hope this helps someone.
It’s unfortunate that we can’t really root it, on the classic K1C version it was way easier than that :frowning:
No supporting Orca Slicer is showstopper for me. I hate Creality Print. It is pretty buggy and user unfriendly. Orca is also not working with CFS.
New versions of CrealityPrint are no longer full of glitches :eyes:
Very disappointed with this. There was no indication that this was the case when I purchased. The salesman even said it could be upgraded to the CFS in the future.
I cannot access the video feed on the 8000 port either
Same. Really hoping for that firmware update
Thanks for info on WebRTC. Got it working. Actually there is exploit to get root at Creality K1C 2025 Root Exploit · GitHub , worked well for me on V1.0.0.26.20251024S firmware.
Port 80 is just a iptables port-forward to 8081.
I don’t expect much from Creality updates. I think they are fully aware they are violating GPLv3 and v2 licenses. And they are not alone. Elegoo (https://freethecode.lol/) was doing the same.
I have a rooted 2025 K1C. C0debrained/creality-k1c-tools on github. It was a bit of a headache honestly but i do have root access now
You might have root but no helper script no nothing, And most importantly, theres no sw recovery yet, if anything goes wrong. Creality said root is gone to avoid people bricking their machines, yet all they did is a sure fire way to bricking instead of letting us do it the easy safe way.
Hey guys, any update on this root access? My K1c arrived today with same issues.
