K1C and Unmentionable Mentionable
Okay and So,
The machine stopped responding and the IP Address would not resolve even with the correct credentials.
Luckily, I had the guts to do a default reset to the beginning of the machine status.
I just performed the reset and put in the same credentials for passwd and SSID. It worked…
So, this is just a post on what to do when your device does not resolve your IP Address correctly. For instance, it could see the SSID but would not accept the passwd for the SSID. Blah…reset to factory default did the trick.
