K1C + CFS Power Sricpt (Helper Script Update for CFS)
Where do I even start? Let’s just say I got tired of how little support Creality gave to those of us who upgraded to CFS. Leaving users with half-baked firmware is a real lack of respect. Here’s what we got:
  • CFS randomly disconnecting
  • Bed coordinates wrong on Y
  • The nozzle never gets cleaned
  • No way to use 220 in the slicer
  • Temperature problems when switching PETG ↔ PLA (and back)
So I did what any stubborn maker would do: I rolled up my sleeves and started improving the Helper Script to add CFS support and make it work with Orca Slicer. :hammer_and_wrench:
What’s already working (tested on my own printer, so I’ve suffered for it):
  • :white_check_mark: Bed coordinates and cleaning area fixed
  • :white_check_mark: Bed leveling no longer heats the bed (cold-bed users, this one’s for you :snowflake:)
  • :white_check_mark: Most Helper Script modules integrated
  • :white_check_mark: Works with Orca Slicer: just pick your colors in the right order, 1 to 4. (I’m looking into a widget for Fluidd so you don’t even have to think about it.)
  • :white_check_mark: Power Screen install support (screen improvements, still in beta, but it works!)
  • :white_check_mark: M600 now cleans the nozzle on the brush in the purge area before pulling the filament out. Finally, a printer with manners.
  • :white_check_mark: With Power Screen, you also get an M600 popup
And there’s more cooking in the oven. Better CFS support is coming soon. :eyes:
I hope it’s useful to you. Feedback, ideas, bug reports and even complaints are welcome, since that’s how this gets better. If it saves you even one failed print, it was worth it.
:backhand_index_pointing_right: https://github.com/borferkic/K1C-CFS-Power-Script
If you like it, drop a :star: on the repo. It’s free and makes me very happy. :slight_smile:
I updated some options to give better performance for CFS!
NOW CFS IS WORKKING WITH EXTRA FEATURES!
Hey I saw your work! This is an amazing project! It looks really promising. Are there any bugs you’re still fleshing out and/or aware of?
Additionally, are you having Claude look through some of the issues described in the forums, and seeing what claude can do about it? I know some issues are resolved with existing tooling, but it would be nice if the helper script also fixes all the quite frankly silly problems CFS can have (For example, if we have 2 figurines printed on the left first, then the right, upon finishing the print the nozzle head will bump into the left figurine on its way to the cutting block + purge. It’s very stupid bug. Or the fact that if we use 2 different types of filament (PETG and PLA) in 1 CFS print, it will default to 250 instead of 220 on purge for both. etc. There are many more issues probably described in forums)
I’d contribute but the development pace of this project is insane! And it looks like you have a very clear vision. So I’ll keep watching for now. AI FTW
I’ll look into the issue you mentioned with the figurines and run a few tests this weekend.
The temperature issue with PLA and PETG, I’ve already fixed the problem where the purge temperature would increase unexpectedly, but I only bought PETG today, so I still need to test it better.
One thing I did fix and thoroughly test is the random CFS disconnection issue. That now works 100% reliably, which is great because that bug was driving me crazy!
Honestly, Claude has helped me speed up development quite a bit. Reviewing every section of the code manually was exhausting. I started tinkering with this stuff back when I got my Ender 3, just to learn everything on my own, but with Claude’s help, I was able to reduce what would probably have taken me months into roughly one month of work. It also makes the QA process much faster! :smile:
