I have changed the hot head of my k1c which includes a filament feed. How do I disable the original feed which keeps telling me the filament has run out please?
Regards Tony
Regards Tony
Was there a manual with the new head?
Hi, Yes there probably was ,but alas my wife immediately bins all packaging once the item has been removed from its box. So annoying, although spent 60 years trying with zero success. ( also puts two hands on one side of a a steering wheel when turning still after 60 years LOL). So if you have the answer PLEASE!
Regards
“Bin” you wife…
Maybe you can find a “manual” online… or ask the (re)seller of the head if they have info!
Thaks but looked. Will look again, just thought someone might know the immediate solution.
Regards
Do you have the DXC extruder? If it helps, I’m about to install that one. There is a runout sensor to that, and it plugs in just over the feed motor connector. The other sensor on my K1 Max is located at the rear right of the machine. It is black and has an arrow on it and a fingerprint. It is attached with two bolts. Undo those and unplug the white connector at the bottom. You will need to carve away the glue with a knife connecting the sensor to the wires.
Hi, Thanks, you have just what I needed right in your reply. Will do that!
ThaThanks Tony
