K1C glass print bed plate availability
In the YT vid " Fixing the Creality K1 Series bed warping with the Sub Bed Mod" by ZeroDotCMD a K1C glass print bed plate is used. The vid is 9 months old and so far the glass bed link for purchasing the print bed plate is dead. In the Creality EU store there is no glass print bed available (anymore?) so the 2 questions I have:
  1. Is this Creality glass print bed still available somewhere?
  2. What is the next option and I guess the answer is to order a glass plate at my specification at a local glas manufacturer and question no. 3 is following from here:
  3. What glass thickness I should take to withstand the highest bed temperatures before it cracks.
vid link: https://www.youtube.com/watch?v=6vU0u630IjU&t=2s
I think best option look at your local glass maker or hardware store, you usually can find some suitable size or cut to size to your need. Just make sure it tamper glass and high temp rated. I think the stock is around 4 or 5mm so you probably aim for those.
Barry,
Ok, thanks for your reply. Correct that the glass should be tampered as bed temperatures can rise to 115 degC for specific filaments. The replacement of the default print bed by a glass print bed is doable looking at the video but I will start 1rst with the 4 leveling wheels+springs to see if that gives me a better leveling position which is now around 0.3-0.4mm on my K1C.
