K1C Max 2024 extra screw
Hi, I have the 2024 K1C Max model an d after changing the hot end, heat sink and extruder I have an extra screw left over and I cannot find an exploded view. It is a counter sunk 14mm bolt, any idea where this should be fitted?
Probably the same place you took it out from! :grin:
Did you remove the dust covers and look around for an obvious missing screw? I’ve taken the extruder apart, on my K1C, but I didn’t end up with any extra screws after it was assembled.
@John_Will yes took it apart again and again just to be sure.
Very odd, it’s not like it’s a tiny screw that could be overlooked! :confused:
14 mm bolt is pretty big…
Yep, I have to believe you’d notice some issue with that missing. :slight_smile:
Were you rebuilding an engine on the same work table maybe…?
Not an M14 bolt.
There are 3 screws that hold the PC board just behind the front fan.
Another place with long screws - hold the stepper motor and the extruder to the frame.
There are two screws not shore of the length that hold the heat sink, sitting behind the pc board.
Bill
