K1C stuck at “Preparing…” – Hotend and bed stay at 28°C after V13 board install
Hello everyone, I need help with my Creality K1C. Since installing the new V13 pcb, the printer no longer works correctly.
Here is the problem:
  • The printer starts normally.
  • It shows “Preparing…” on the screen.
  • After that, no matter what I try to do (preheat hotend, preheat bed, start a print, etc.), the hotend and the heated bed stay stuck at 28°C.
  • The temperature does not move at all, even if I try to heat both hotends and the bed.
  • The printer never begins heating and never leaves the “preparing” state.
What I have already checked:
  • All cables are correctly connected (heater, thermistor, bed, ribbon cable).
  • The thermistor shows 28°C whether it is plugged in or unplugged.
  • Firmware is updated.
  • I reinstalled the V13 board carefully.
  • I followed all the steps Creality support asked for.
  • I sent photos, videos, and my invoice.
Current situation: It has been 3 days and Creality support has not given me any real solution. They only said they “checked my case,” but I still have no fix and the printer is unusable.
My question to the community:
  • Has anyone had the same issue with the V13 board on the K1C?
  • Did you find a solution?
  • Was it a defective board, a cable issue, or something else?
  • Did Creality eventually send a working replacement?
Any help would be greatly appreciated. Thank you.
I currently have a ticket opened with Creality on the same issue. It started after I removed the nozzle to unplug it. Any type of activity on the screen results in system preparing message, please wait. I also get a nozzle abnormal temp error and the nozzle remains at 28C. No response on my ticket as of today.
Replace the nozzle assy and all is working normally.
K1 Series Accessories HubK1C Ceramic Heating Block Kit(New Version)
I have the same issue, I did the factory reset and now freezing on preparing system
Same here with v12 board.
Has anyone been able to solve this as im having the same problem
