K1c with Board CR4CU220812S12!
I recently bought a K1c Printer from an AliExpress seller.
The device worked fine until I tried updating the firmware. My current firmware version is 1.3.2.31, which is missing some features, and the printer doesn’t recognize any updates.
I found out online that this problem is common with the CR4CU220812S12 board.
However, the official site appears to only support the CR4CU220812S11 board.
After opening the printer, I confirmed it is indeed a CR4CU220812S12, which is quite peculiar.
Has anyone else experienced this issue and can offer help?
My printer too has this board, and it looks as if it is a new upgraded board see Amazon.com: Original K1 Max Mainboard Silent Upgraded Motherboard with TMC2209 Driver Compatible with Creality K1 Max 3D Printer Replacement CR4CU220812S12 32bits TMC2209 X2000E : Industrial & Scientific. I bought my printer from Creality.
Yes, this is the new board for all K1 series; I have received confirmation from Creality that it will work with the different firmware.
Did you ever get a resolution from Creality for the CR4CU220812S12 motherboard issue? I’m have a serious problem and sent them a picture of my motherboard with the the same number. They have yet to respond to my proof and today I had to escalate to the US Customer Services.
yes they contact me and insure the FW is safe to apply to the both model the board will flashed correctly if you use the official FW
What firmware do you have installed? where I find it?
you can find all the firmware in creality.com choose the last one for your printer
I have a K1 with the cr4cu220812s22. due to a display faillure in the main board. I ordered a new one from amazon.com. For my surprise, there are two fan connectors missing. same cr4cu220812s22 discription, and no fans.
