K1max firmware upgrade to 1.3.5.22 cam stop to work
I’ve solved restoring 1.3.5.19 firmware and all is ok.
As declared in notes of 1.3.5.22 look at item 1
V1.3.5.22 Firmware Update Notes:
1.Optimize video stream transmission security.
2.Optimize model fan control logic.
The stream transmission security is so optimized that the cam stop to work for security.
Please review the security or go back to the previous software.
With 1.3.5.19 works really fine
It worked. Thanks for the tip.
hello . i have the k1 SE and happened the same . i tries rollback but it’s older version and the s12 board don’t accept it by usb stick. what can i do?
After the latest firmware upgrade, the camera here no longer works via the web interface either. Can I get this working again via settings, or will there be new firmware released soon that fixes this? It works via the software, but it doesn’t work via the web interface anymore. I think it has something to do with ports or something similar. Awaiting your reply.
So, waiting for the real upgrade
Where can you get the firmware update 1.3.5.22? The creality page doesn’t list this one.
I’m seeing the same issue on my Creality K1 after updating to firmware 1.3.5.22 — the camera stream is no longer accessible via direct browser IP or in OrcaSlicer’s device tab. Creality Print still shows the camera fine, so it looks like the update moved the camera off the stream those other clients rely on. Just adding my report as another confirmed case — let me know if there’s any info I can provide to help track this down.
Same for me too.
I, too, have this issue. The camera doesn’t work with the IP address web page but it works with Creality Print 7.0. Is there a fix for this or should we just bring the firmware on the K1 Max back to 1.3.5.19 until the next upgrade?
I came here to see if the problem was solved and to reinstalled the new firmware. It seems like it has not. Wonder what the hold up is?
i just also noticed that port 4408 is not working either, kinda dissapointed becuase was just trying to print ,noticed the zheight was kinda low so just wanted to raise the zheight during print until i re level and bedlevel tune in fluidd with it not working, shoulda known better than to blindly think a new firmware would be a good upgrade
