K2 Bed Leveling
Good afternoon. This is the profile of the bed I get. I’m trying to adjust it manually with the screws. Everything remains approximately the same.
Someone has encountered a similar problem. what to do?
I don’t see your profile, but I am going through the same thing after I discovered last week that printing anything close to the rear-right of the print was badly formed. I also tried a manual level last night and was unable to make any difference.
However, when I first discovered this I did try another test - I flipped the magnetic plate, the default one with the printer, so that the smooth side was facing up. I reran a level calibration and this time it was far far better. So I am thinking it’s the plate and not the bed. I did try to flex the corner with the problem, but it makes no difference.
I’m expecting another plate this week that I ordered last month, so it will be interesting to see if that makes a difference. If it does, I will be claiming a replacement from Creality.
On my K2 plus, I had the same problem. After many attempts, and after removing the construction surface, I realized that the four screws were turning at the same time as the screws underneath, which are therefore absolutely useless. I solved the problem by gluing these screws to the heating plate with a small amount of contact cement
Remove the magnet plate, use a allen key to hold the screws on top and turn the knop under the bed.
