K2 digging into my build plate
I need help. New to this and after just 2 weeks of owning this K2 pro I went to print tonight and when it started doing its level check it went all the way up and then the printer nozzle drug across the plate leaving deep scratches
You updated the firmware recently? Many people are complaining about that same issue. If you did update, you should downgrade back to the older firmware.
I did update when I took it out of the box. I will go back to the old firmware and try it
I’m having the same issue. How do I go back to the previous version?
こんにごは。
ć‚µćƒćƒ¼ćƒˆć«å‚·ć¤ć„ćŸćƒ—ćƒ¬ćƒ¼ćƒˆć®å†™ēœŸćØēŠ¶ę³é€£ēµ”ć™ć‚‹äŗ‹ć§ć™ć€‚
ē§ćÆę­Ŗćæć‚»ćƒ³ć‚µćƒ¼ć‚Øćƒ©ćƒ¼ć§ć—ćŸć€‚
ę­Ŗćæć‚»ćƒ³ć‚µćƒ¼ćƒ»ćƒ›ćƒƒćƒˆć‚Øćƒ³ćƒ‰ćƒ»ćƒ—ćƒ¬ćƒ¼ćƒˆćŒé€ć‚‰ć‚Œć¦ćć¾ć—ćŸć€‚
Hello, please watch this tutorial https://youtu.be/LVTEGkVRSwY?is=3d45sQg8lvS2vaEB Regards
