K2 Nozzle Camera Failed to Start
I keep getting this message. “ACO529: Nozzle camera failed to start, try restarting” but I’m unable to find any information on it. Has anyone else had this issue or know a fix?
I got this printer brand new Friday and have only printed a few things so far.
Have the same problem here.
Brand new printer and every time this error.
I reached out to customer service and they had me restore to factory default.
I did that and it seems to have fixed the issue… so far.
Hoe did you set I back To factory default? Because I can’t find it in the menu.
Found it and after I did the reset did two prints without the error. Hopefully it’s over now.
Thanks.
Cihazda bir noozle kamerası olması gerekmiyor mu ? Creality K2 Combo.Bende de aynı sorun var ve kamerayı bulamadım.Söktüm , kamera yerinde yok.Kamera koymayı unutmuşlar.Bu modelde kamera olması gerekiyor diye biliyorum.
Bende de aynı sorun var , kamera yerini açtım baktım kamera yok
Merhaba, Creality K2’nin baskı kafasında kamera bulunmuyor, sadece baskı tablasına bakan bir kamerası var.
still have the problem after 2 restarts no info on it might be a bad bored or something. if anyone found a fix beside replace bored plese inlight me!
I bought my K2 Pro at the beginning of July ‘26 and it ran fine until it did a FW upgrade. Then I started getting that same error. Tired downgrading the FW but still no good. Support sent me a new nozzle cam and still same problem.
What is the original FW loaded from factory?
