K2 plus not cutting filament
I have the k2 Plus. Just recently it stopped cutting the filament on multicolor prints. I’ve tried orca and Creality print and it happens with both. Filament change comes up it goes to cut position sits there then goes right back to purge chute. It don’t try to bump the cutting arm. It worked fine for about a year then just started this problem. Only thing that changed was the installation of the dxc2. I had to change the couple settings they recommended. It worked normal after that for like a week then started skipping the cutting action. Idk what else to do to fix it. I have update/downgraded firmware and factory reset multiple times. I do have k2 improvements installed for the cartographer but it was working fine. Someone please help I can’t find anything on this problem except for few post but they didn’t have any clue what was going on either
