K2 Plus - Overheating issues?
I’m curious if anyone else has encountered this issue. ((EDIT: Error code on printer is “2561”, not appended with any letters.))
If I pre-heat everything to get things nice and heat soaked (bed 105+, chamber temps 60, hot end 270) maybe one out of every 3-4 attempts to print results in the printer abruptly turning off… Lights turn off, bed falls etc. After a minute or two the machine will light back up and the display screen works (stating unknown error) and the only way to get things back up and running is to cut the power off.
If I hop into fluidd, the last transmitted message appears to be advising that I’ve lost my connection with the nozzle (Nozzle MCU connection error).
This hasn’t ever happened on something like PLA or any lower-temp filaments, only when I’m preparing for a PC/PA-CF print or the likes…
Even though it’s only intermittent - things like this rarely improve over time and typically only deteriorate once a problem starts so it has me worried. Anyone with any input/thoughts/ideas/suggestions??
Thanks!
With a heated chamber, K2 is supposed to be an engineering printer, capable of printing engineering materials that need higher chamber and bed temp. Sadly, tons of problems arised when we increased the temp. From extruder clogging to bed warping, and now in your case, either loose connection due to thermal expansion, or the print head controller screwed at high temp.
If I may suggest, try cooling the extruder as well as the print head board. I use 20 lpm aquarium aerator with 8mm silicon tube. It helps me a lot with extruder clogging problems, maybe this can help your case as well. I have been considering cooling the control board also, but maybe later.
I generally print in PC (270 nozzle, 110 bed with a 55 chamber) or ASA - and my best prints come from disabling all of the fans so it does get pushed hard. I also have PPS-CF, PPA-CF, PET-CF, ABS/ASA-cf on hand with a custom 1mm nozzle. Just ordered all metal gear replacements for the extruder that should be here in 8ish days… Doing a lot of custom parts for BMWs (also have a Raptor Pro) so this machine will for sure be pushed hard, but I do keep up on maintenance.
No problem with the extruder and no bed warping ?
Any relation to error TE2564 “The nozzle is not heating as expected” which my printer just threw up on it’s first print today? The help page talks about wiring issues…
https://wiki.creality.com/en/printers-general-documents/TE2564
Mods; if unrelated please say so and I’ll start a new thread…
HC, I definitely need to heat soak everything well before running the calibration in order to deal with the warping – but as long as I’m patient even with about .8mm in variance the printer does a pretty good job with it.
Don’t heat soak the nozzle with filament in it. Just in case you are not aware, the filament will degrade quite quickly if left at printing temperatures. It can de-polymerise and leave clumps in the nozzle which will block it. Sometimes the residue from chronic overheating of the filament will adhere to the sides of the nozzle.
Sorry, no idea what your error is but I will echo other words here - if it is sold with a heated chamber and advertised with the ability to produce long prints at the maximum settable temperature (which is??) then every single component in there has to be able to run at that ambient temperature, before you even consider the self heating of semiconductors, steppers, etc, and heating by the filament heater. Look around inside and ask yourself if every component meets that criteria. Belts?. Bearing lubrication?. Ambient temperature for stepper motors?. All electronic components in the head. And there is thermal expansion causing errors - do you see any correction for that, or floating mounts to avoid buckling. If the answer is yes for every part then it’s a good machine capable of professional use.
Update!
I ended up replacing the entire hot end, and WOW. It made such a massive difference.
I went from having semi frequent issues (especially with filaments like ABS/ASA) to absolutely flawless prints using factory settings preloaded into the slicer.
Night and day difference, can’t emphasize this enough. Quality went from OK to absolutely outstanding.
Did you replace just the hotend or the entire toolhead?
