this is after todays update along with creality print.
when starting a print from Creality Print, it will perform auto bed calibration every time, even when disabled. to avoid this, you have to send file to printer and start it from the screen and uncheck auto calibration.
Also, another issue, the printer still waits for the bed to go down to 50C, which makes you wait forever and you cant exit or do anything. this issue was present before todays firmware.
if this is intended, atleast let us turn on the side fans so it can get the temp down faster.
Dug around a bit. If I send the print file to the printer and then select it on touch screen, uncheck calibrating. It will heat the bed and start the print. If however i send it to print from Creality Print 5 or 6, the K2 will heat to set temp (70c) then cool to 50, then start the print inc callibration. Really annoying!!!
I would not do that change as it affects other cases as well.
Anyhow, the new Version 1.1.1.7 is set that way that it automatically does a bed calibration on first print after bootup. As long as you do any print with bed temperature 50° (I use a small disc as a test model) you will be save. Therefore for all my PLA print’s I don’t care, for PETG or ASA… I do not print them as first print but print just a small test model before @50. For the rest of the day there is no problem with temperature or calibration anymore!
