setting the speed to 50% gets reverted back to 100% after color change.
im pretty sure this is not intended…
Yes, really annoying, should be able to select more of a range, like 20, 30, 40… and it should stick for rest of print unless manualy changed!
yep . I observed that as well… and it’s sucks. I was hopeful the new firmware was a resolution but the other issues introduced have me not even thinking about this issue for the time being…
Same bug still exist, any Idea how to bypass it or how to report to creality?
Add this gcode to the layer in the slicer M220 S80, this is 80% m220 s50 is 50%
add it to the gcode?
where exactly, and won’t color change override/reset it.
I tried and applied it from the prompt, bit it’s also reset when changing color?
Same issue with current CP version. Still not fixed. Very annoying as everyone has said. Agree, adding the gcode would help provide a temporary fix, but I would like to see this fixed. Also agree, we should be able to select more speed choices.
Still an issue! Any ETA?
K1 Max with the CFS upgrade kit installed - looks like its also reverting back to 100% speed between changes, annoyingly.
USE SILENT MODE FOR SLOWER PRINTING !!
It seems that SILENT MODE is runs at 50% and stays slower than 100% AFTER FILAMENT CHANGE !! but you might want to play with fan speeds.
Unlike 50% Mode that Reverts Back To 100% After Filament Change…
im not sure why they refuse to fix certain issues or make certain changes from older machines to new machines which clearly Are Not Better Changes.
my E3.Max Neo + Sonic Pad DID NOT have this problem, if i told it to run 50%, it stayed 50% even after Manual Filament Change.
but That might be why right… its not loading filament profiles…
