K2 Plus won't print
I have had my k2 Plus for about 8 months and, other than a few minor issues, it has worked fine. However, since last week, I have not been able to print anything.
I am using Creality Print 7.2. The print sequence starts out as usual, model downloaded to printer, printer goes through pre-print routine, then pauses and won’t print. If I push the restart print button, Creality print briefly indicates printing being restore, then goes into pause mode.
I am not getting any error messages. I have done any recent firmware or software updates. I have reset the print to factory setting and un-installed and re-installed Creality print on my computer. I have run the calibration routine several times.
Nothing has worked, so I am unable to print anything.
Can anyone help me fix this?
Are you familiar with the FLUIDD interface? It probably has more clues and it has logs to see exactly where the fail occurs. I recall having an issue like this, but I forget the solution. Only that the answer was in FLUIDD and no clues in Print 7
Went back to 7.1 and fixed the problem with the K2 hope the next version fixed es it. 7.2 works well with the HI and the K1c
