k2 Plus Z axis motor not working
Z1 Axis Failure – Error Code CM2789-Z1
I am experiencing a Z1-axis failure with error code CM2789-Z1.
I have inspected all accessible connections, and everything appears to be securely connected.
When performing calibration, both the X and Y axes operate properly. However, when the printer attempts to calibrate the Z axis, the Z2 motor operates normally while the Z1 motor remains completely unresponsive.
Based on these observations, I suspect one of three possible causes:
  1. A defective Z1 stepper motor.
  2. A failed Z1 motor driver on the control board.
  3. A defective connector or connector pin within the Z1 wiring circuit.
Proposed Diagnostic Procedure
I would like to interchange the Z1 and Z2 motor connections to help isolate the source of the failure.
If the problem transfers to the Z2 motor after swapping connections, this would suggest an issue with the motor or its associated wiring. If the Z1 circuit remains unresponsive regardless of which motor is connected, this would indicate a possible failure of the motor driver or control board.
Unfortunately, performing this test requires disconnecting motor cables. I am reluctant to proceed without authorization, as I do not want to jeopardize the manufacturer’s warranty.
My questions are:
  1. Has anyone experienced this particular failure or error code?
  2. Is swapping the Z1 and Z2 motor connections an acceptable diagnostic procedure?
  3. Can this test be performed without affecting the manufacturer’s warranty?
  4. Are there any additional diagnostic procedures you would recommend before replacing components?
I would appreciate any technical guidance or recommendations.
To prevent direct disassemble.
The the printer is turned of can you turn the Z1 shaft by hand? Not with tool or anything just you fingers. It should be fairly easy to spin.
Ehen it spins easily there is no lockup on motor or shaft. Contact Creality for the steps to proceed.
If it doesn’t spin easy there are 2 possibilities:
  1. motor lockup (broken)
  2. the nut travelling up and down the shaft is block ( mainly due to small filaments parts)
Disconnect in both cases the shaft from the motor and find the culprit. A new motor can be ordered online. When the shaft is frozen remove it from the printer with the nut. Use a lint free cloth to hold the shaft and inspect the thread, when it looks clean find if one of the turning directions feels more loose. Make sure when trying to turn you don’t bend the shaft. Back the nut through the way of least resistance, when it turn very easy from one moment check the shaft for debris. Clean the shaft, assemble everything and make sure to grease the shaft properly.
Please update with your findings
