K2 Pro HotEnd
Hello everybody!
I need a new hot end for my K2 Pro.
Is it the same used in the K2 Plus?
Thanks in advance.
I think so, vendor told me its was mainly just heater wattage size but I still got K2 Pro version as they had it in stock and its was same price anyways.
Thank you for the answer!
Well, I am actually a beginner in 3D printing, so forgive me if my terms are not the most appropriate…
OK, I’ve acquired the K2 Plus hot end and this is my experience till now:
The dimensions are the same as we would expect. The K2 plus kit comes with 4 short screws, although the K2 Pro uses 2 short and other 2 longer ones. I’ve used the original screws from my printer. The fitting is perfect including the electrical conections.
Regarding printing there is a very strange situation… during flushing, when the wheels of the extruder stop spining, the melted material continues to drop from the nozzle for a few seconds. Even when the print head leaves the flushing zone and moves to start printing it is still droping material which is obviously problematic.
I also note a lot more spider web effect than before, and the detail in some printed characters is not good. I’ve only used PETG with this new hot end. The usual temperature was 240-250ºC and I’ve already reduced it to 220ºC. Is better now, but not good yet. And the over droping is still ocurring. I will test with even lower temp…
Maybe this hotend is much more powerfull than the K2 Pro one.
I’ve read that using Retraction can help reduce the spider web effect and eventually the over droping. Any ideas about configuration parameters?
Thanks again.
Ah could be, I did get K2 Pro version, so that could be case with different mounting hardware.
Maybe there is slight different thermistor type perhaps as well as heater wattage, maybe try doing temperature tower and see if notice its requires less temperature or higher for that material.
HI again. I confirm that the thermistor cable of the original K2 Pro is labeled 320ºC while the cable of the new hot end regarding K2 Plus mentions 350.
Regarding heating power, the K2 Pro says 70W. There is no label in the K2 Plus heater cables.
So the printer was eventually “feeling” a lower temperature and overheating the nozzle…
The nozzle in the original hot end seemed to be partially obstructed, and that was the cause of my initial problem. I´ve exchanged the nozzles on the hot ends, so now I am using the nozzle of the K2 Plus on the hot end of the K2 Pro. And it seems to be OK now, printing at the usual temperatures.
Anyway, I must say that, as a few users have already comented, I don´t understand why we still can´t find all the spares regarding the K2 Pro in the Creality stores…
こんにちは。東京からです。K2Pro・K2plusのホットエンドは日本の公式ショップでは在庫切れで入荷のめどが立ちません。AmazonでK2plusのホットエンドを¥3,999で購入しました。AmazonのAIはホットエンドメーカーはUnTak3DでCreality に納品しているとチャットで回答してました。現物を確認するとiTunesさんの仰る通りです。今使用しているのが壊れたら交換してみたいと思います。皆さんのアドバイスに感謝です。エクストルーダーはK2plusと同じ部品です。交換部品として送られてきました。
追記:歪みプレートもK2plusと同じです。これも交換部品で送られてきました。
According to Creality the answer is no. I had the same problem, the hotend just up and died. The problem with the K2 Pro is you just cannot get parts for them in NZ. No one stocks the Pro parts, only the Plus. So I raeached out to Creality and there answer was no, and they don’t have parts for the Pro either (Australia). I had to wait 3 weeks for a hotend. In the mean time I brought the Plus because at least I can get parts for it in NZ.
Hello J nunes, you can get it on Amazon, use this link Creality K2/K2 Pro Hotend - Conjunto de blocos de aquecimento de cerâmica para impressora 3D, acessórios para impressora Unicorn Quick-Swap, resistente a altas temperaturas de 300 °C, design integrado : Amazon.es: Industrial e Científico
Merry Christmas
Hmm, my local vendor have hotend split up into two different sku, I ask them, apparently there is slight difference in nozzle, which is old.
According to everything I’ve looked at, the Pro hotend is 70w and the Plus hotend is 100w.
You should do the PID calibration for the hotends when you swtiched to th 100w. I replaced even my k2 basics to the 100w heater and it prints much better
yes they are the same
