K2 Pro Multi Color Print object complete with one color
Is there any way to print the complete object with one color before changing filament color to print other parts of the model.
Yes, easy. Call print by object in all the slicers. Issues re: fitting them all on one plate sometimes.Look under other tab, special mode, print sequence. Change from by layer to by objecvt.
See the red doorframe, can I print the whole doorframe at once without doing a filament change every layer. The machine went through 416 filament changes. Too many filament changes.. Thank you for helping me.
Sincerely
Rick Palmer
All colors on the same layer red and white, black red and white in the current view of the model, would require the poop and filament changes.
To print all one color you would have to print the tower separately from the base and fence. Then print the base all in one color but from the base to the fence could be only one filament change. The other option for the tower as separate piece if you oreint the tower so the red is the last layer(s) then again, only one filament change. But as you have it shown, if it is all one piece, yeah, lots of poop.
