K2SE multiprint fails half way through
I have a K2 SE and when I print a job with multi colour it stops with an error for the cutter, but the cutter is ok. It looks like the head does not go and cut the filament. it just moves around and says the cutter is jammed. it does not move to the back and try cut.
こんにちは。
エクストルーダーにフィラメントが詰まっているのでは?
Hi, no the head does not go back to the cut zone. it is as if the program does not tell it to go cut the filament to do the change
