I have noticed that when I perform the automatic bed leveling, that the offsets tend to indicate that the bed is a little high at the front. While the auto leveling is detecting and compensating for this error, would it be any benefit to shim the bed to improve the level?
Thanks
Rich
As I understand it from the more experienced forum users: No for a number of reasons. However it couldn’t hurt. If the shims don’t work then just take them out. Just make sure you calibrate again before/after modification.
Here’s an interesting video about bed leveling I found :
https://www.youtube.com/watch?v=8PEsPLDxt-c.
Lensman
Thanks for the reply and link. I watched the video and the pre-heating time is interesting. I will have to try that.
Best wishes
Rich
Hi,
My V3 KE also show very high in one of the corners on the Web page of the printer. But the auto leveling solve those issue completely.
For testing those I created 22x22cm(0.2mm height) flat square in Blender and printed with initial layer speed 200mm/s (travel speed 300mm/s2) and initial accelerations print 800mm/s2 and travel 1000mm/s2.
I get totally perfect surface (practically membrane due very thin) with those settings without any Z level problems. If you print with high speed (above 300mm/s and above 5000mm/s2) dont be surprised if you have Z level errors those initial layers need to be slow.
Do you have a picture of that test print? I’d be interested to see the quality.
Give me a day I will print out again tomorrow. And upload both the model and the picture for Creality Cloud.
Here is the Creality Cloud link: Ender-3 V3 KE Z-layer testbed URL
Interesting your slope (deviance) is pretty close to mine. It looks like you too have some high and low spots on that test print?
Just an update.
After using the auto bed leveling I noticed the front right corner (Y0, X220) still had a small error with Z axis. I ended up placing a small flat 0.7mm washer under the right back corner (Y220, X220). Now when I do the auto bed leveling the graph shows a much flatter bed and the Z axis in the right front seems to be doing better.
K9WG
Hello
I wanted to know if anyone has experienced this problem with the auto bed leveling, because every time I start the print and proceed with the bed calibration the bed temperature is always set to 60°C.
I did a manual test and by setting a temperature to 80°C I have more deformation on the perimeter of the bed.
So the printer does the bed calibration but as soon as the printing starts the bed temperature increases and the values on the edges change leading the calibration to be less effective.
Does anyone know how to impose the bed temperature when it does the calibration?
I manually set the temp and let it set for 10 - 15 minutes before I initiate the bed leveling.
