Key Error: 2022 (X-Axis)
Hello, I’ve purchased a brand new Ender 3 V3 KE. After setup language, acceptance of licensing terms and timezone selection, the self check procedure is failing with Key Error 2022 after the X-Axis move all the way to the left and make some noise like it still want to keep going left. I’ve check the endpoint switch and it seems ok (1-3 close, 2-3 open, and when i press the switch, 1-3 open and 2-3 closes).
Is there a easy way to query the printer with the command M119? To see if the board is receiving the correct endpoint switch states?
I’m new to 3D printers.
unfortunately there is not. i am having the same issue with mine. my printer failes due to a Abnormal Nozzle. I have been round after round with tech support. They are very slow to respond and, little to no help at all. I wish there was an easier way to troubleshoot issues.
