Lack of extrusion after initial wipe, V3 KE with upgraded hotend
I have a V3 KE that I’ve been using fairly problem free until it got the blob of death. I decided to upgrade to the new ceramic hot end (partly because there was still a lot of plastic stuck to my old hot end), which I installed, and I had to readjust the Z height (I used the correct length tube). The issue is that after the initial wipe (printing via Creality Print) where the nozzle is purged correctly, the first layer starts but nearly no filament comes out. It prints like this for a few seconds, and only then does it extrude normally. I see the extruder gear turning, and I see the filament moving into the head, but very little filament comes out (wisps). The issue is that the first layer is ruined because of under extrusion. The hot end fan is on and blowing in. Is there anything I’m missing? Do I need to adjust the print settings for this new head?
