So, I haven’t printed in a while and decided to yesterday.
I am not having this layer issue. What would be causing the shifts in the layers?
PLA+ on an Ender 3 V3 SE with Nebula pad.
Currently running the preset temp tower in calibration section of the Creality Print software and it is turning it into steps. i clearly have an issue somewhere.
Check the belt tension, x and y. Check the x-axis gantry parallelism to the bed. Check the z is perpendicular to the bed. Check the z axis leadscrews are clean and lubricated. Check the screws that attach the x-axis gantry to the z-axis aren’t too tight, tighten them up then loosen them a couple of turns, the slop will take out the z wobble in the lead screws.
Turns out the issue was with the Nebula pad. I reconnected the original dial screen and no more issues.
