I am at a complete loss as I can’t find anything on this issue.
On my V3KE, only on my first pause, the bed will crash on the Y-axis into the front of the frame with a thunk and I will have a layer shift of about 5mm. When I resume the print, the layer shift happens, but on every pause after that I have no layer shift and the bed does not crash into the frame.
I have even tried changing my G code in the end settings from Y228 to Y180 and it still crashes on the first pause, then follows the gcode change on every single one.
I have tried seemingly everything. New firmware, changing g code, checking tension, checking obstructions, auto homing, nothing works. All help is very much so appreciated.
have same issue.
I actually solved this issue, need to make minor changes in config files, need root and winscp , need to make change in y axis parking position in pause macros .in my case it was 223 , changed it to 220
