I’m using a Creality LD-006. I performed the alignment with the paper and set the home position, following all the instructions.
However, when I start printing the piece, it prints “correctly,” but it creates the initial layers across the entire build plate. I set 9 initial layers, and it’s creating 9 layers across the whole build plate before starting to print the actual object.
I also noticed that a lot of material remained stuck to the FEP film.
I tested the lcd doing a dry print, and the lcd is perfect.
What could be causing this?
