Linear X axis rail MGN12 for K1 Max use stock 20 t pulleys without rooting?
I have printed a set in petg for linear X axis rail and bought a 400 mm rail mgn12 +railcarriage mgn12 and want to use this to replace the x axis rods on my K1 max.
I have the 20 teeth pulleys and will not change those.
Can I do this without having to root my K1 max???
who can answer this question for me?
Rails are just a slide thing so it shouldn’t affect anything.
According to numeorus people who prints for Voron and Rat Rig, you should use ABS od ASA for mechanical parts, not PETG.
thank you for noticing
I get in Asa tomorrow and reprint the parts
I have installed the mod.
The mgn rail hitted the back steppermotors lightly at the nozzlecleaning proces but I solved that problem…
But the results are very good and vfa has vanished. I have to tune in some more to get everything in the right order.
got everything in right order now. printing with linear rail is fine an improvement I can say.
old model on the left with a lot of vfa and new one on the right with less till almost no vfa.
