Lines in Z axis
I’m getting lines on the Z axis of two identical core XZ printers. They are in the same place on both printers and there will be a couple in a tall print. They are exactly the same distance from the bottom and from each other. I am using the Creality slicer on Creality print. I suspect the slicer most. I don’t see the same exact problem on 2 printers with the same file. I have tried .2 and .08. There was no change. The lines look like a single layer and they look like an axis jump or under-extrusion.
It doesnt do it in vase mode. Vase mode is perfect. I think I need help with slicer settings
