Luminous PLA Issues with CFS
I have a 8 month old K2 Plus with CFS. For the first 5 months I had no issues. Then I started printing with Hyper Luminous Blue PLA. For the last 3 months I have had no shortage of issues including:
  • Failure to retract and extrude issues
  • The printer will stop extruding mid print but not detect the issue and continue resulting in unfinished objects
  • Fail to unload the filament when commanded without manually helping give it a tug
These issues started with just luminous blue and in CFS bay 4, but now happen on any color in any CFS bay that is printed.
I have tried to:
  • Replace the PTFE tubing in the CFS although it didn’t appear to be very warn and I have only printed about 150 hours total
  • Tried changing the temperature that the luminous blue is printed at thinking it could be heat creep, also printed with the top of the unit open
  • Tried repositioning the CFS
  • I took off the extruder cleaned all gears and removed any debris (this was minimal)
I also purchased another CFS so I could use more colors and I’m testing that one on a white PLA and luminous blue print right now. That one seems to be working ok although we are in mid-print…
Is this a faulty CFS? How do I resolve this issue
From WIki Replace worn CFS PTFE tube and Maintenance | Creality Wiki -
" 1. Maintenance cycle of CFS PTFE tube
Under normal usage frequency, it is recommended to replace the PTFE tube every two months to ensure smooth filament feeding and retraction in various scenarios. For abrasive materials like fiber-reinforced filaments, it’s advised to check monthly and replace promptly when obvious wear is observed."
  • Luminous Blue PLA. very abrasive plastic…
Hello,
I was wondering if you figured out your issue with the Luminous PLA. I have been trying to print with it recently and had nothing but trouble. I have tried the same things you have but I keep having issues with it stopping to extrude mid print. I thought it might be the filament itself but I tried 2 different Luminous PLA and still same issues. I have tried so many settings and im using a 0.6mm nozzle.
Any advice?
Don’t know if this will help I was having printing issues with the standard Hotend but I changed it for a Micro Swiss Highflow hotend. I think creality seriously need to sort out the quality of this sort of thing you should never have to go to and out sourced part to make their machines run better. Frustrating indeed. I still have issues with my first 2 layers of print from time to time, it’s really not consistent at all
Are you using a harden nozzle.
I have also read that with some of these filaments you should go to a bigger size nozzle, 0.6 or 0.8.
I have used Flashforge Luminous Blue & Polymaker Luminous Orange several times with no problems.
I’ve read that the luminous, the marble and other specialty filaments have problems with standard nozzles.
I had the same issue, replacing the heating block solved all my issues at once.
Ik heb dit zojuist gevonden op AliExpress:
Creality K2 Plus keramische hotend-kit, K2 Plus snel verwisselbaar mondstuk, volledig metalen snel verwisselbaar mondstuk en 300 ° C Upgrade-onderdelen voor verwarmingsblokken
https://a.aliexpress.com/_EQtLzd0
Thank you all for your responses. I messed around, with the tubing a bit more since it seemed a bit suspicious so when I removed the tubing it actually started printing. So I think ill be looking for a better PTFE tube maybe with a larger diameter to have the filament move through it with less resistance.
I effectively rebuilt both CFS’s last night and cleaned or replaced every part of the pipeline. I’m still having consistent issues with retraction and extrusion. For what it’s worth I haven’t had any problems with the Bambu H2C on the luminous blue. That’s not to say it has been issue free because it hasn’t but the AMS have been more consistent so far.
I found that the issues I was having was with cardboard spools or spools not wide enough. I make sure to use strickly plastic spools and use mainly creality spools or,beleave it , Hobby Lobby spools.
