So I’m not sure if this is the place to ask… I’m at a.loss right now.im on the latest firmware. Updated but haven’t used it untill the past 2 days. So basically it always worked as it should. Just on wifi … I could print from the app, from the browser , it would show up as online on my workbench …I also have a k1 max and can see it online as well. SO . For some reason now only halot Box can see it . I can load an STl…support it and send it over wifi and print. …it works great… But it does not connect at all to the creality cloud… App, browser , anything to do with creality… it won’t connect to check for firmware …online models … nothing at all. I have factory reset it multiple times, redid setup … scan the QR code with the app…it adds fine ,and yes I have removed it from my account as well… it adds it back every time… But always shows it offline… I have even tried wired and the same results… it won’t see firmware loaded on a usb stick… I have tried like 6 different ones… Sorry for this being so long but I am at a loss right now on why? Is there another way to factory reset? Ssh and flash it some how? The only thing that has changed is the firmware… Anyone have ideas?
I have the same issue. Always shows my printer as being offline.
So you can still print from Halot box correct? But everything else acts like it has not internet connection… I can’t even read files from my usb.hbu?
I have to load the files onto the usb drive then put that into the printer to print.
