Magnetic mat peels off the printing table
I am using my K2Pro for about 5 months now,
Since about 1 month the flexible magnetic mat, that is glued to the printing table, starts peeling off, therefore it also lifts the print bed.
I tried to find a heat-resistant 2-sides-adhesive foil to fix the problem, but until now with no success.
Does anyone of you suffer the same problem? Did yousolve it? Thanks!
こんにちは。
それはサポートに連絡した方が良いと思います。
私もK2pro昨年8月から使用してます。
稼働730時間で、テーブルはフラットです。
… what did you do to the heated bed? Used some aggressive cleaner on it?
I have the same problem with my K2 PRO, when I heat up the bed to 90-100° to print ASA.
No solution yet from Creality support.
@Mr_MBR the problem is the magnetic pad, not the PEI printing plate
YOU DON’T READ! I haven’t said anything about the PEI sheet…
No reason to scream. I just think that the chemicals are used to clean the PEI build plate, not the magnetic pad.
I can for sure be wrong…
@Nuxil Did you ever find a fix? I have the same issue i cant seem to solve.
Thanks.
こんにちは。
エラーを正確に共有するために写真をUPされた方が良いと思います。
3Ⅾプリンターには色々な問題が出てきますね。 :joy:
