Messed up Firmware Help ender 5 pro
Hi all My S-Daughter decided to help me and has taken an interest in 3d printing.
Unfortunately, she has managed to screw something up with regards to the firmware.
She did a firmware update, not sure how she managed it but when I got back this weekend there was a load of firmware updates on my PC, it would seem when she updated and the printer went a bit screwy she tried multiple updates to the firmware, she said at one point it all came up in Chinese. Figured out, she went onto the Creality site from what I can see to the correct page but has managed to try all of the firmware for this printer without checking to see if it was 8bt or 32bt
anyway the old version that was on it from what I can remember was
2020-04-25
Ender-5 Pro
Extruder:1
Baudrate: 115200.
Marlin
Ver 1.0.1
2020-4-25
Ender-5 Pro
it seems to be a Creality v4.2.2 y3 , motherboard… Arm STM32F103 chip
new firmware
the one that is currently installed is
from what I can tell it says
Creality 3D
2.0.6
Sep 22 2022
Ender-5 ProCreality V4.2.2
Extruder:1
I can get the machine to kind of run but when I send to print either with the Memory card or via PC it looks like its printing but all that happens is the screen shows printing climbs up after maybe a minute it says completed but all that has happened is that it shows 100% on the screen nothing moves on the printer itself I’m hoping that is just a setup issue something missing or not set up properly I can get the y.x. z to move. via motion controls and the heating to work. but when I switch it on the bed is around 3" lower and does not lift to the print position also if I hit the home function it moves to the top right and then moves to almost the centre of the plate, also I can’t get the bed to move up as it shows zero at the motion function and won’t go below 0000 I can drop the bed no problem and raise it to the oo mark but I can’t get it any closer to the print head without manually moving it and then it just resets itself back to the 3" from the Printhead.
can anyone give me what settings I should be showing on the screen etc Help:
Maybe you’ve already tried, but have you reset the printer factory settings? Just a thought :+1:
can that be done on the control screen or is there a hard reset on the Motherboard
Yes it can be done from LCD screen
Go to the Menu and select ‘Settings’
Select ‘System’ and then select ‘Factory Reset’
You may have to set up languages, time zone etc all over again but it will reset your machine back to the original settings.
Hope this helps :+1:
nope that must be a different system there is no way to do that from the screen seems that the only way I can see would be to install the original Firmware via sd card unfortunately I don’t have it I need version 1.0.1
Did you ever resolve this? I’ve tried to reflash the FW but it is not taking. I am unable to check the screen because it is blank :grimacing:
Im curious if there is a way to factory reset without using the screen.
