Minimum power to fire 60W in Precise mode?
Hello. I did a low speed, low power material test. 100-500 mm and 1% to 5% power.
Only the 5% column showed anything and it showed at all speeds. It’s as if there is a minimum power % to fire the laser.
Hi,
I have seen similar issues. In fact I am still not sure if the laser power adjustment within Lightburn even works. I do not seem to see much difference when I change the laser power.
I am engraving at 5% but changing to 20% does not seem to change anything.
Anybody has a suggestion?
