Modify the infill density in specific regions
Hello,
I have a print where a narrow region broke off as I removed the support so am looking to add more infill to that area. I saw in a infill guide that you could modify the infill density in specific regions but I can’t find anywhere that explains how to do it? Any help would be appreciated.
Thanks.
Hello @Koffy …! :wave:
There are a couple of things you might try as Creality Print 5.xx doesn’t have variable infilll as of this posting.
I believe Cura 5 has it but I haven’t used it yet.
You could try to add some strength to the walls and experiment with this setting:
Another thing to try is set the infill a lot higher and click on AI Infill:
It tries to figure out the best way to place the infill.
In creality print 5.1 right click your object choose add modifier , then in object mode change that modifier infill settings to what you want. Where they overlap you will get the new infill setings
