This is a 3d printed Moon wall lamp.
Printed on my k1max, total diameter is 540mm
it is already cut in 4, for smaller 3d printers just resize the parts to satisfy your needs.
It has a channel where the wires can hide behind, and a channel of 10mm for led band.
Printed at 20 %infill, 3 walls, i had also ironing on, i think it should work without also.
It needs support active on all 4 parts because in the middle of the moon is a cubic cut space for cables.
If printed in one piece it should work without supports.
I put it on the wall with double sided tape.
I used a 24v led band, but it will look pretty awesome if a dimmer is used to light it less, so the shaddows will look awesome.
Link to the model Lighting & Lamps STL Download - Wall Moon Lampby RCalin
Dont forget to like my post here on forum <3
