I just unboxed the machine and the screen won’t turn to face front. I’m afraid of forcing it. Anyone else have this issue? How did you solve it?
The display is actually quite stiff to move, but don’t worry it was the same with mine, you can still rotate it forward. Just make sure you don’t twist it, apply the force of the rotation directly along the axis, and nothing should break.
Yes it does take some force to move it. I ran into the same thing at first. After double checking that I was doing it right I got it to turn.
Yes. The display is hard to turn. It require a little bit of extra force to turn the display. When I unbox mine. I got the similar situation too. Just making sure you turn it to the correct direction.
