Multiple problems with a 3 day (!) new K2Plus + CFS
My new K2Plus worked fine for 3 days. Then on day 4 I turned on the K2 and the issues began. The K2 was not showing up in Creality slicer. Ping was no problem. Started Fluidd and there are errors regarding Klipper. Also extruder errors. Fillament stuck but after disassembling the extruder was fine, no fillament in it. Firmware update gave no solution. Also multiple error codes of which I don’t know the numbers anymore. Also Hub fillant feeder errors. The lever in the hub is stuck and the only resolution is cutting the fillament. Then I tried to install klipper again but even more errors arose. So I had 3 days of pleasure of working with the K2 and then only issues.
So I’m not a technical guy regarding ssh access and fixing things in code. I just want to USE the K2 not addressing and fixing issues. (The same applies for my car: I want to drive it, not fixing it constantly)
My question: If I replace the motherboard and the extruder, you all think it will resolve my issues?
I manageed to resolve the extruder and hub issues. So only Fluidd issues left.
What are the problems you got with klipper ? Dont think you had any software problems only some fillaments some where stuck in the ptfe tubes, cfs or hub. think you need to reset the firmware and try again.
Can’t use Fluidd. IP adres and port (4408) are ok. I got error messages that klipper is not connected and “cannot connect to moonraker”. Using the K2 by slicing and save the gcode to an USB stick oor using Creeality Cloud works fine now. Also the K2 is not visible in Creality Print.
Can you provide more info on what you’re doing to solve the problems you’ve had? I got my K2 Plus and had what appeared to be dozens of retraction and feeding issues. Nonstop.
